Plasti Dip
The wheels and side mirrors look great on your Sti. Definitely going to get onto doing the mirrors with the wheels. Hey Mattapo, if I just go about PM\'n you for an order would that be alright or through the site?
I\'ll make sure to post some before and after pictures of the car. Going to look reeeeeeeal good.
 ADIKT']
Are the wheels easy to keep clean?
[quote name='lerroy said:
Yeah how does it hold up does it peel easily, scratch?
Easy to keep clean, taken through the car wash plenty of times and it is perfectly fine, hand wash is ideal... even with a water blaster its fine...
Only peeled when I got my tyres changed, from the machine grabing the rim.. witch I was expecting to happen(only peeled parts of the lip) so I fully peeled off and resprayed the worst rim easy enough. So yes peels easy and with 4-5 layers its not going to scratch.
Ive had mine done for 6 months or so now and its just like they were sprayed from day1 apart from the peeling from the tyres being changed.
Hope that helps :-\
Edit: They also recommend to sand any curbed areas, just to make the surface smooth. I didnt do that cause I didnt want to sand the gold off and mine are fine.
