Darth Vader noise in B4
Jailbird
Hi all,
last week i replaced the heater core, after getting it back together after a long day or two,
started up first time with no problem, but when i put it in gear the engine light comes on and flashers :\'(
and in the engine bay there is a Darth Vader sound coming out of a black box drivers side next to pod filter, and cos of the sound its not boosting in the primary. but 2nd seems fine,
took to inter-cooler back of to see if i had missed a pipe or vac hose was not on or cracked. ???
car was running fine before the heater core change, off chance i missed i plug??? putting dash back together
ideas....
cheers
The only time my BH5 makes a Darth Vader Noise (from the BBOD), ;D Is when it\'s in D-Mode. Would also cause the CEL to flash constantly when you try to drive it.
Make sure your Green and Black Diagnostic Plugs aren\'t connected. (Under dash above drivers feet)
