Factory Momo steering wheel with airbag
tydon
OkI am guessing that your car has no SRS from the factory and you want to fit a later model SRS equipped wheel to it, the only issue I can see is that the "airbag" is actually moulded to the centre trim of the wheel so to remove it will leave a gaping big hole in the centre and no horn buttons
also as the horn buttons are wired into the car via the clock spring, even if you remove the airbag you will have to find some way of rigging these to work.
may be cheaper/easier/safer/more legal to buy a boss and then get a wheel when you can
