V7 wrx to sti headlight conversion
scylar
 Rosssub']
[quote name='Rosssub said:
That plate that the ballast was attached to is steel, it looks like the ballast itself is earthing to that plate.
I think you should take the short black wire coming off the ballast and earth it straight to the chassis.
ok wil give that a try.. what would i do to the black wire on the headlight itself? ground it to the chasis as well?
Yip, both straight to chassis.
will give it a try and see.. hope it works or im buying me some bulbs lol
Trust me, afaik I\'m right. ;D
so funny thing today i just tested it with the suggestion but didnt work. i bought me some new bulbs too just to make sure and still no go.. :-\
anyone got a spare ballast i can test on my system? lol
I have the same kit on my car installed by previous owner, the high beam has blowen. I had brought a 60 phillips bulb :-[ didnt realise this was a hid kit.
Where can i buy a high beam? I presume needs the harness piece attached? Not a direct bulb replacement?
The high beam is a regular h3 bulb. If you have the lightwerkz harness then plug the socket with the yellow rubber on the h3 bulb
