 Rosssub said:
LW red - brown
LW black - orange
How many spare fuses have you got? ;)
2 more. Lol hopefully the relay didnt get affected after it blew or the ballasts lol
 Rosssub said:
LW red - brown
LW black - orange
Quick question. The other socket on the ballast which has got a triangle socket, my headlights socket which has got the orange wire cover doest match up as its a rectangular shape, do i just splice and match up? Like orange to orange and brown to brown?
 scylar']
[quote name='Rosssub said:
LW red - brown
LW black - orange
Yes.
If there is a third, black wire? It goes straight to a solid earth/chassis.
 Rosssub']
LW red - brown
LW black - orange
Yes.
Thanks will try first thing
 Rosssub said:
No worries, good luck. ;D
no go on that.. changed the fuse, relay, still no go.. wonder whats wrong.. its just the low beam thats not working
 Rosssub said:
Where have you connected the LW main earth?
Is it the top plug that is different for you? Orange and brown instead of blue and black?
yes i have the orange and brown instead of the blue and black then i plugged it red to orange 1st and brown to black, fuse blew, now red to brown and orange to black. nothing is happening. changed the relay just in case still no go
Now that you\'ve swapped the orange and brown over, did the fuse blow again?
Edit: In the Pic you can see the orange and brown coming out of the ballast, leading to the blue wire. To double check they are around the right way.
yes checked. i basing from that pic orange is on left and brown is right. swapped and they didnt blow... cant think of anything wrong.. what can you suggest i do next?
 Rosssub said:
Silly question I know but...Have you double checked the bulbs since the short?
Edit: Also check all fuses in the engine bay fuse box.
yeah i did, i only used one pair which was the right side on the first stuff up.. but could be that too.. i used the other bulb and other ballast on the next try. still nothing.. would the bulbs be affected as well as the ballast when it blew?
 Rosssub said:
Looking at wiring diagrams, the low beams get their power from the lighting switch.
The lighting switch fuse is the small 20a fuse in the engine bay box, (closest row to battery).
checked that and its working.. tried to stuff in the original headlights, went on fine.. used the a light tester and was still fine
Just been looking at the Head light wiring diagrams again.
Both the High beam and the Low beam share power source, linked in the headlight itself.
The lighting switch is the earth for the low beam.
If your high beam is working fine, then the ballasts and power source are good.
Have you got the small black earth wire coming from the ballast? Have you run it straight to the chassis?
yes i have a black ground wire coming from the triangle shaped socket on the ballast but id doesnt connect to the ballast itself. its just screwed on the bracket. what did was tapped the black wire that comes from the headlight (black wire coverd by orange wire cover) to the chassis and left the black wire from the ballast (black wire which is screwed to the bracket) alone
That plate that the ballast was attached to is steel, it looks like the ballast itself is earthing to that plate.
I think you should take the short black wire coming off the ballast and earth it straight to the chassis.
ok wil give that a try.. what would i do to the black wire on the headlight itself? ground it to the chasis as well?
 scylar']
Yip, both straight to chassis.
 Rosssub']
will give it a try and see.. hope it works or im buying me some bulbs lol
 scylar']
Trust me, afaik I\'m right. ;D
