Gear Box shaking
Hi all, I\'m looking to buy a 2007 Subaru Legacy 2.5L manual wag. I did the drive test, all feel good but the only thing I am concerned about the 5-speed gear box. The gear box itself has no problem (I hope), it shift gear smoothly. But when I put my hand on the gear knob, it seem to be excessive movement/shaking of the gear stick under normal operating condition.
My questions are:
Is that normal for manual Subaru?
Is there any other common problem of this particular model?
Mine shook sexcessively hard when a coil lead came off and was running on three (uneven force distribution causing it to wub wub wub like a rotary, sounded mint lol) it does shake a little bit normally. but that may depend on condition of mounts and bushes etc.
If you\'re used to driving a car with a cable operated shifter then it may just feel like it\'s shaking a lot as it\'s a mechanical shifter linkage?
If it\'s excessive movement, it could be a broken mount somewhere. It\'s usually the older models that break the engine mounts so I\'d guess that it\'s most likely just the normal vibration through the shifter linkage.
