v7 imprezza window issue?
whatchain
hi, our cars windows is acting weird. eg when you set the rear right window down from the drivers side switch panel its fine but it wont go up when using the same switch? and its the same with the front passenger side too will go down using drivers switch but not up, however the rear left side works both ways from the drivers side switch. can anyone suggest whats causing this? why do some go down but not up? i took the door cards off and nothing looks tempered with..
Not sure if the version 7 uses the same window control computer, but it might be a reset issue:
http://clubsub.org.nz/forum/showthread.php?23116-Electric-Window-reset-woes
http://clubsub.org.nz/forum/showthread.php?10624-Is-your-drivers-window-doing-weird-things
Either that or dirty/corroded contacts inside the drivers door/window switch control panel. Pull it out and open it up, clean all internal parts/electrical contacts etc with 'CRC Contact Cleaner'. Any corroded contact plates can be given a light sand up with fine sand paper/wire brush.
