1999 legacy b4 wiper problems
gtlegacy
heya,
my girlfriend has just bought a subaru and its just rained lol the problem is the front right hand wiper is funny the rest go fine
what happens is that its like the wiper goes to far on the wiping motion and then the returning motion and goes off the window and trys to wipe the drivers side to then coming back it bangs down on the bottom on the window/steel
any idea?
does it have original spec wiper arms/blades(they sometime change them in japan)
is the pivot bearing warn(check that the pivot shaft can not wobble)
next check the linkage bushes they are usually plastic and will fail
The wiper linkages under the plastic cowl panel below the windscreen have plastic bushings that are real common for failing. The drivers wiper smacks the pillar then the cowl panel. They're around $120 for a new set of linkages last time I checked.
