Overboost issue
tydon
v3/4 converted GTB legacy
so ive sort of fixed half the issue its intermittent now.
On full throttle it will spike up to 20psi mayb more my gauage will only read 20 and it will then boost cut.
sometimes is will boost solid 16psi and not spike.
Ive tried 3 other boost solenoids and none made a differnce ive double checked wiring and everything is where it should be.
i swaped A3 and A19 on Plug B137
ive run wastegate pressure from turbo nipple to gate actuator with no problems.
 Rosssub said:
Reading that restrictor pill thread, the JDM version 3/4 WRX uses a 0.9mm pill.
http://www.perth-wrx.com/vb/mechanicals/48287-restrictor-pill-what-why-you-need.html
I'm currently running 1bar/14.5psi. Set up copying this turbosmart install:
http://www.turbosmartusa.com/wp-content/uploads/2011/12/Incabin.pdf
Page 16 of my conversion:
http://clubsub.org.nz/forum/showthread.php?43004-Rosssub-s-Single-Turbo-Conversion/page16
No, restrictor pill comes out. The MBC has it's own restrictor built in. I could turn it up to free boost if I wanted.
I turned it up 3 clicks this morning and spent the day at a solid 18psi (14.5 before). It has about 15 more clicks to full.
