ECU Repin/Swap
Ok, so ive got my head around 95% of the single turbo conversion. Except the ECU part. Strong for Subaru said ill just need a ECU from impreza wrx. They've quoted me the right one, im just not sure exactly what i have to do regarding the ECU part of the conversion, is there anyone who can either tell me the process or link me to a page with it all on there? Some of the ECU swap pages are only for EJ20R engines and i have a manual transmission EJ20H. So if anyone could help me out that would be really really great :)
Thats one of the harder ECU conversions and I don't believe that a straight swap is worth it i.e. using equivalent WRX 4-plug ECU and keeping the grey injectors.
You need to swap about 80% of the pins on the ECU and change a couple of wires around under the bonnet.
The old pinout list for this conversion is this one;
But I also have a colour coded one here which has a few more instructions on it: https://www.dropbox.com/s/fo77a7bk8l51eg2/ECU%20Pinouts%20BC5%20BG5a%20WRX%20%284%20plug%29%20-%20Single%20Swap.pdf
But if I was to ever approach this conversion again myself, the only way that I would ever consider bothering with the work would be to use a 3-plug STI ECU and convert to V3/4 STI single turbo. So would also require yellow injectors, correct AFM etc.
Takes more work and parts to achieve the conversion but gives a much better result.
The electrical side isn't much different to swapping in a 4-plug WRX ECU (Tip: 3 of the 4 plugs on the 4-plug ECU's can be used for a 3-plug conversion as they're the same plugs. You just leave out the 12pin plug).
In this case you'll need to use a V3/4 ECU pinout list to compare and swap around the relevant pins. Some sensors may also need to be changed but if you buy a complete manifold then most of that issue should be solved.
