ej205 vs ej207
codyjesen
Whats each engine out of as above? ej207 is v5/6 sti or v7/8/9 sti with avcs. Comp ratio is different and wirings way diff between v5/6 and newage. If its a forester or wrx with offset coilpack then you need to swap ecu at minimum and running an sti ecu on an ej205 generally leads to mass det. Thats a start.
EJ207 of that era is STI? Guessing you have an STI and you want to do a cheap fix by dropping the EJ205 into it? If so don't do it get in touch with fbssub on here he has a full STI long block which will drop in for 1.4k on tm.
