Sti gauge swap. ABS / brake light issue.
wyatt31
 Rosssub']This relay is a 5 pin N/O N/C, so has both a 'normally open' and a 'normally closed' circuit built in. Just depends which contacts are used.
http://www.surplustronics.co.nz/products/4007-heavy-duty-relay-12v-dc-coil-40-amp-230v-ac-contact-dpst-no-nc
Looks like terminal 87 for normally closed relay, or terminal a87 for normally open:
8375-medium.jpg?1381804944
cheers man
[quote name='DRFVDR said:
whats your brake fluid level like :)
Surely that won't affect it hahah besides if i plug the original cluster in the handbrake light functions as normal.
alright so. I cut the abs wire (b3) green/yellow strip and plugged the end coming from the cluster into the switched circuit on the relay and the other end onto the other plug for the switched circuit. Then i cut the ground wire (c6) and plugged the ends into the remaining plugs on the relay only to find that it did nothing.
So i then cut the power wire ( c7 ) and plugged that into where one of the ground wires were and that just caused the whole cluster to be dead. nothing came on.( i put everything back to how it was btw, so the clusters not broken hah :) )
What have i don't wrong ? help lol
alright so i wired it up like in the picture you posted and it did nothing. So i switched the abs wires the other way around and that turned the abs light to permanently off which may not sound like a problem, but the abs light need to come on during start up then turn off in order to pass a WOF. and ideas ?
