Clock-room fuse?
FST4RD
Having issues with the my 99 gc8 draining the battery. I did the pull the fuses whilst I have a multimeter in series on the battery.
The only fuse or relay that changes how much is being drawn on the battery is the Clock-room fuse in the engine bay.
What exactly does this fuse do? It seems to control the the door sensors that turn on the interior light?
I pull it, the alarm goes off, I reset the alarm and it beeps as if a door is open.
I checked the door sensors and they all seem to work properly including the boot.
Can anyone help?
Battery is not that old, also had 3 separate tests on it from different people, all came back fine.
Can't remember exactly how many amps now, but after pulling all the fuses and relays this was the only fuse that changed the reading. How many amps is normal?
There is also a clock fuse inside the car, so are there 2 clock fuses?
