V6 wrx boost controller ideas
markw336
Hi all I have a V6 wrx wagon and I want to wind the boost up to 12 psi I'm pretty certain the factory controll solenoid has packed a sad and the car is on spring pressure and I don't know if I should get a bleed valve style or cheap electronic boost what's everyone's thoughts
Yep idles smooth just gave it an oil change last night put some penrite hpr 5 in it and this is going to sound silly but it's now boosting almost .7 of a bar so bout where it should is it at all poss the old oil was to thick or I have a failing oil pressure sensor?
I don't think oil consistency would have an effect on boost levels? Now getting 10psi it could just be crap blowing out of the boost lines, maybe cleaning the solenoid out freed things up a bit.
Definitely pull the boost hoses off and give them a blow through. Or could be a boost leak, or BOV not holding shut.
