Hiya people,
I've tried searching on the differences between the bc-5 rs and gt ecu's, and i understand that the RS's have an 8-bit ecu and the gt's have a 16-bit ecu...the reason why I am asking is I am looking at buying a link computer out of an rs legacy but I have a GT...I'm wondering if this ecu will run my car fine or if it will infact not work in my car?
Thanks.
You are incorrect on the 8 bit RS and 16 bit GT.
It is generational for both models. Same year/same ECU. The differences were what was written into the programs.
Series 1 = 8 bit
Series 2 = 16 bit
Any 4 plug Link will go straight in regardless.
 CUDDAS said:
Hey hi there, I too am interested in finding some info on my ecu's as i have an 89 RS, & 90 GT & have used both ecu's & with 2 type's of chip's in my cars, At the moment i'm running on a RS loom in my GT
C7
22611 AA740
A11-000 RA3
with a modcontrol chip. 4 PLUG ECU
ALso have
C6
22611 AA600
A11-000 RA2
with a chip that was in my GT when i bought it. If any one has some info on these 2 ecu's. THANKS
C7 is an Auto 8 bit code.
C6 is a Manual 8 bit code.
Are both chips 8 bit?
Differences would be negligible, besides Boost control for VF10/VF8 which i would say share the same wastegate spring setting (6psi)
 BC5RA said:
Some would say there is no such thing as a manual GT.
I've seen all sorts of discrepancies.
AFAIK all Wagons were GT's regardless of gearbox
Manual Sedans=RS Auto Sedans=GT
hence my FACTORY Manual Wagon was a GT but had the bigger turbo and manual ECU
but now it is eg33 powered :)
Guest Oscar
 DRFVDR']
This will confuse you then. My manual GT wagon had a VF-10.
Guest Oscar
That is true, but dealership parts system confirms VF-10 from the factory.
 BC5RA']
C7
22611 AA740
A11-000 RA3
ALso have
C6
22611 AA600
A11-000 RA2
Would you know what a K3 is for?
this is true, all GT (wagon) came out / should have come out with VF10... i was looking at doing a GT restoration with my mates car so he is doing everything by the book, man trying to used orginal parts is costly these days
 Oscar']
Must be a GT specific item rather that 5MT.
K3 is a 16 bit RS ECU.
 BC5RA']
now that is very interesting, that is what i have currently in my 92 GT... (does that sound right?) because the other ECU i was going to try in it to eliminate some issue is the C6 i have...
but i'm assuming 8 and 16 bit are not going to be transferable? should my non face lift wagon be running a 16 bit ecu (might be my problem right there?)
    574.7k
