Idle control valve.
Percy
So I pulled the Idle control valve tonight to clean it a bit, and it exploded into several bits halfway through cleaning, which was slightly awkward.:confused:
Has this happened to anyone else?
Also does anyone in CHCH have a spare one? as the car doesn't run very well without it, which is not very surprising...:(
Or how much a new one is likely to be?
When I was attempting to move it, by pushing it in I might add, the plastic bit that seals in the throttle body came off in my hand, and the spring flew out into the engine!
Managed to find the spring luckily,but now it really doesnt work!
The car wont idle steadily, and occasionally will rev to 3000+ for no reason.
Luckily I still have my old car as the GTB is a bit undriveable like that...
And apparently there are 2 knock sensors listed for that engine, and I have no idea which one mine is, so tonights job is find the damn thing so I can see which connector it has!
Moving the stepper motor plunger while it's out can throw the ECU off. Providing it went back together ok, you could try a sort of IACV reset:
- Reset the ECU.
- Turn ignition on (don't start), wait 10 seconds.
- Turn ignition off, wait 10 seconds.
- Repeat ignition on/off 3 times.
- Then start and leave idling till warm before driving.
Oh yes, great success!!:cool:
No CEL's, no random loss of boost, goes like it should when applying jandal.;)
Let the enhancements begin!:D
Like replacing the turbo to IC hoses, as one has a crack in it, dodgily repaired with a soldering iron, a MTB inner tube, and a metric s%$#tload of zipties, which will hopefully last until the silicone ones arrive...:rolleyes:
