Brake cooling ducting
Most race supply/performance shops should be able to supply proper heat resistant brake duct hose, but it is quite pricey. If you don't want to fork out for that stuff then go to your local Blackwoods Protector (or Hose Supplies) store and ask for some TPR (Thermo Plastic Rubber) Duct hose. This works well and is a fair bit cheaper than the "proper" duct hose. Comes in a range of sizes so should be something to suit your set-up.
TPR is the stuff I used years ago on my old Hillman Hunter, worked pretty well and never melted, and as they weren't vented the brakes on that thing would get HOT!!
Like turn the discs blue and set the dust on fire hot.
