Wiring in a standalone
I'm planning an adapter loom using the V5/6 ECU plugs you gave me, so will be reusing most of the OEM wiring. Anything in the engine bay that isn't used I'll cut the plugs off and insulate the ends, then label and tape up into the remaining loom.
Gives plenty of options for adding extra sensors and solenoids down the track, like AVCS etc without running new wires from the ECU. Also because of the adapter loom any unused sensor/solenoid signal wires wont be connected at the ECU end.
Things like the OEM oil pressure switch and coolant temp gauge wire will stay connected as is. Also planning to keep my AC for the mean time so that will stay connected as is too. The test mode connectors under the dash can stay in place because they wont be connected at the ECU end through the adaptor loom.
I've already got my TT differential pressure sensor wiring still in place to use for IAT sensor. Most of my TT BBOD solenoid wires are already trimmed and insulated inside the BBOD.
Changing to a version 7 TB so will have 4 spare IACV ECU wires for V7 map etc. Then original AFM wiring can go to something like a right bank AVCS cam position sensor etc. Any wires from plugs that get cut off will be labelled then taped up, so I don't have to go wire chasing with a multi meter later on.
