GC8 stage 2 tune
timmy31
 GC8E2DD said:
In regards to this, Brad's appears to have made closer to 170kwatw @4k rpm? And that was with the VF37, and before the motor rebuild. That seems pretty solid! Probably more than my car makes at peak.
Numbers are numbers only. Prob hub dyno as well. Bigger hotside on vf36/37 means slightly power. Obviously its t/s but gains arent huge against s/s with vf.
Edited by evowrx
  • 2 months later...
 evowrx said:
Thats all cool...Eculabs do V5/6 but again whos tuning it and need to send a donor ecu to France...
I am the EcuLabs distributor for Australia, I have stock on exchange all the time. Got V5/V6 STi, WRX, 98~00 B4 Twin Turbo and 98~00 Forester GT in stock
ESL is good value for what it is AND it is easy to use if you have used EcuFlash before
Screenshots of the map based software for v5/6? And how much?
What can you guys do with a RevC B4/GTB twin turbo ECU?
  • 3 weeks later...
Australian V5 2 Door STI known as ARGO, its a dedicated track car.
Pricing varies depending on the Euro:Dollar but typcially AUS$500 posted on exchange(I have stock, post it to you with a cored deposit, post back stock ECU for full core deposit refund etc) plus price of the custom tune etc if wanted or doing it yourself etc
Heap of extra options available though :)
http://www.eculabs.com/
Screenshots on the website
If you could get some confirmed (or more exact) pricing for NZ and an easy way to work things, I imagine you'd get a lot of customers relatively quickly Mr Happy
The ECU's themselves are available cheap as here so I can't see exchanges being a major issue
 Marky']If you could get some confirmed (or more exact) pricing for NZ and an easy way to work things, I imagine you'd get a lot of customers relatively quickly Mr Happy
Yeah, looking at options while I am over there. I may be setting up a dealer/tuner in Auckland for them :)
[quote name='evowrx said:
You can etune these?
Yes, e-tuned a few of them. Tune themselves is pretty solid gains. Typically 180 to 190Kw on 17psi on 98RON, Seen 230Kw with decapped injectors on E85
Other way is to contact me for postal details and you can send an ECU to France yourself and have it posted directly back(less postage etc)
