Single turbo swapped BG5 - No idle?
megamac
Have finally put together my wagon. Have yellow injectors and orange AFM with 6s ECU.
Now when I start it, the revs go up to around 3500rpm then drop to nothing after two or three seconds.
I've checked for vac leaks etc, and to make things difficult, it's not even throwing a CEL??? I'm still running coil on plug and have done the wiring to run it. I have the white plugs to the coils at the front of the car and the black ones toward the rear.
Anyone have any idea what could be causing this? Have tried a different IACV also :(
