busted engine mount, now sloppy clutch??
Kiwi_Fozze
hey guys, bit of a question.
busted an engine mount at gymkhana a couple of weeks ago.
in doing so, it sprayed a bit of clutch fluid from the reservoir across the bottom of the I/c
have since changed the engine mounts and have noticed a substantially different response from the clutch pedal
lighter than before, little bit spongy
clutch is a little less grabby
clutch slips when you give it some boot
clutch engagement is right at the very top of the pedal travel. like, you sneeze on the pedal and it disengages.
part of me is thinking if I bleed out the clutch it should fix it, as I assume when I busted the engine mount it caused some f**kery with the clutch.
I find it very unlikely that the clutch plate itself is borked, as it's had 1500km since I bought it, and maybe 1000km if that on previous owner (club member) looked brand new when we put it in... and its only been like this since the mount went.
anyone have some insight? need to get it sorted this weekend, really don't want to drive to flatnats on a slipping clutch
Brake cleaner would be my guess... but without actually removing the clutch I don't know how you'd be sure to get it cleaned properly,
and then with the amount of work required, you may as well just replace the disk with a new one.
