dash lights flashing
ajb86n
na sorry should have been more accurate with what i was saying
so the fuel and temp guage are fine with lights on just the speedo and rev guage lights sorta flash wont stay solid oh and the clock light doesnt work at all
ive changed over the fuses but no good
couldnt say if it had been removed mate sorry guy i got it from was not to much help and no dimmer switch i can see it stays solid for a couple of minutes(normally when warming it up) then just flashes its hard coz i work early mornings till late at nite so leave home in the dark get home in the dark all other lights work also if that elimanates anything have to keep my cell lit in my hand to see how fast im going haha
had problems with these before when i was working for wingers. its quite common. it has something to do with alternator voltage spikes. we used to call Automasters here in Auckland to sort it out. they do some modification in the alternator wiring to solve this issue. Call Automasters and they will be able to help you out. http://www.automasters.co.nz/.
subaru has also introduced a pak file upgrade to sort out this fault.
