Help required
B4 I was 250T
Hey all. So somethings is seriously wrong with the B4. It's running like ****e, shuddering, jerking, no boost and just overall weirdness. Was forced to leave it at work overnight and after much discussion feel it could be one of several things. I first changed the fuel pump (thanks Ross for the how to) and it is running slightly better but still not normal. So, I feel that that leaves: shagged spark plugs ( car was missing occasionally before this happened ) shagged O2 sensor or shagged MAF sensor. Any advice would be appreciated. Oh, and I can't ask Richard Baddock for help as he's at Waimate 50 this weekend
 Marky said:
I bet 5 internets it's the AFM
Unplug it and see if it runs any different
(p.s what was the last thing you fiddled with on the car)
Just unplug it and go drive? Isn't that bad for her? And funnily enough I haven't played with anything lately, last thing that was done was Baddock replacing the clutch lol
Nah don't go for a drive (tho you can), just unplug it and see if the idle changes, it'll be quite apparent. The car will just go into limp-home mode and -should- bring up a check engine light
When the AFM's in them go bad what they sometimes do rather than fail outright, is just start reading waaaaay off true, so they run like a bag of poos but the car doesn't know it as such
If you pull it out, (the afm element), have a look down the sensor at the mirror surface. If there's any dirt/grit, oil from an air filter or even water staining on it it can make it fault out
They -can- be cleaned but it's pretty hit and miss (use something like isopara alcohol, something you'd use to clean electronics that won't leave residue)
