Fitting additional Gauges...Who can do it (Aucks)?
Garryg
I'm going to change the double din head unit to a single then fit a single din gauge bracket. I'm looking at putting in a boost gauge, Oil Temp Gauge and Oil Pressure gauge. Could anyone fit these for me, or advise where to go? Cheers
if you find the right bits on trade me its no more difficult than changing oil and filter and wiring a head unit .
also id rate a water temp gauge over a oil temp . for oil temp to get to a oil is always hotter and as en engine warning device its far too late . in saying that if oil temp interests you then go for it
if you dont do those things then sorry im not in aucks
Cheers Lachlan, Thanks for your reply. The reason I thought on Oil Temp over water, is that there is already the factory water temp gauge. Although I do my own oil/filter, brakes, I only do these as I'm used to this.. I could also fit a head unit, but wouldn't be comfortable fitting the others in case I make an error and get false readings. This is why I'd rather have someone else who is more skilled do it.
Hopefully I can find a forum member, or some feedback on a good garage to put it in to...then I'll be happy. I've already bought the single din gauge holder and looking at a single din head unit now :-)
