ECU Swap from manual to auto
Legacy05
 evowrx said:
If it was my project id go straight to a wire in ecu and build a new loom its just such a mish pissing round with trying to cut the loom up etc.
My intention for the 818c is to run a G4 with traction control. I will not re use the loom or ECU from the stock motor.
What I need to do is find a stock tune computer that works with my 2005 as I have stripped all the performance parts off it. The modified factory computer will no longer run it safely.
I have now found a 2003 GT ECU that was a manual. Can anyone tell me if that one will work safely?
Gotasuby on here is the chch go-to man for that stuff. He's a very smart cookie
Or even ask NZEFi to do it? They'd charge a token cost to remove and re-flash the ECU but I'd expect they kept your old stock rom on file anyway. It's a 5 min process to plug in and re-write the info, 4:30 of which is waiting for the laptop to turn on
What parts got removed from the legacy?
