Intermittent hard shifting
romeyromes
Hey guys, newbie here!
Just wondering if anyone has experienced what am I currently going through and if there is anything I can do about it. Feeling pretty hopeless right now. I have a 2007 Subaru Legacy B4 with 93,000km's.
Basically, it started with a P1710 fault code. The car would intermittently shift really hard as if another car was hitting me from behind then will go into limp mode. After a few minutes in limp mode, the car would fix itself and start driving perfectly again.
So I got this fixed by a tranny specialist here in Auckland, Auto Trans. P1710 is a Torque Converter Turbine Speed Sensor 2 malfunction. Luckily I am still under warranty.
Once fixed and after a couple of days driving like a dream, the hard up shifting is happening again. But now, the hard up shift only happens right after start up and when the car is cold. After a few minutes, it will again fix itself and drive perfectly. The tricky part is, it doesn't always happen!
I went back to the Tranny Specialist, no fault codes found and because the hard up shifting is so intermittent, they cannot easily identify the problem.
Has anyone experienced this? Any input would much appreciated.
Cheers guys!
Rome
Cheers guys!
Rome
Get in contact with a authorized subaru dealer/ mechanic who can upload the new PAK files for the auto trans (sublab in east tamaki do it)
I assume its a 5 speed - and its doing it from 2nd to 3rd??
I will find the thread with more info - hang tight
Cool thanks, will give them a shout as soon as I can.
The only weird thing is tho, my gears all change SMOOTHLY when the tranny is NOT playing up..
And when the tranny IS playing up, the gears change violently rough. Like really bad!
Edited by romeyromes
im in the same boat i think. when changing down from 4-3 gear the whole car does a thump/jolt kind of move. seems to to do it when it is at a certain speed when changing down... and also when changing from 2-3 gear it will do a thump as well. changing up gears 2-3 is when i use the paddle shift on the steering wheel(giving it a slight bit of stick) and when changing down into 3rd gear is when its doing it automatically.
looking at getting the gearbox serviced with fresh oil and filter as im not to sure when it was last changed. i think ill also look into the pak files etc
I started this thread. Mine was when driving normally and on part-throttle the 2nd to 3rd shift was a firm thump. You'd expect the thump if wide open throttle as it uses full line pressure to prevent slip. I never had it on downshifts. And was intermitent as well, I notced but never thought much about it. Sublabs picked it up when testing driving before a service.
Fixed.
Apparently the the Turbine Converter Speed Sensor 2 that was previously replaced was faulty. Live data showed no feedback during cold start up.
It is known that this sensor is attached to the valve body so the valve body will also need replacing if this sensor needs replacing.
So I guess Auto Trans in Newton Rd Auckland can replace this sensor for a few hundred dollars rather than spending at least $2000 for a new valve body.
It is kind of a short cut job but hey, if it works, it works.
Sadly, I am mistaken.. Violent harsh shifting occurred again over the weekend.
It is clear that this sensor cannot be replaced by it self, the valve body MUST be replaced.
I am now dealing with Transmission Solutions, who are now in the process of ordering a genuine valve body from Japan.
Did you ever have the new PAK files loaded?? I would be doing this before spending money on valve body
No, I didn't get the chance to.
And I'm under warranty and the dealership is paying for my excess so I haven't spent a single cent.
Still frustrating AF tho..
This is the thing, when the car has warmed up nicely.. the gears shift smooth as silk. For all gears, up shifts and down shifts.
When the car is cold, I get symptoms of a failing valve body. Delayed shifts. Violent violent shifts (Wish I could emphasize this even further haha) but when my mum was in the car when it happened, it scared the sht out of her lol.
The car is not in driveable condition while it is cold.
