Smoke on start up
B4 I was 250T
Does it fill up the street with smoke in the morning or just a big puff?
Does it smoke when you throttle off? While on the driveway with a warmed up motor
try holding the revs at say 5000 rpm for a few seconds... when you take your foot off the gas... does it smoke?
Well it's burning oil somewhere
Sounds like it's in the intake
Either a) one or the other turbos is pushing oil out
or b) the motor is pushing it into the intake
Or c) I don't know but a puff of smoke is not a normal startup condition in a 15 year old car
It's normal for a 15 year old car... obviously it's burning a bit of oil, but if it's not enough to register on the dip stick, it's hardly a problem.
Valve stem seals are probably getting a bit tired... maybe the piston rings too... maybe the bores are going out of round slightly... could be many things.
Thanks for the above guys! I really appreciate it! So today no smoke on start up either first thing this morning or after work so f**k knows lol :D Will continue to monitor it and maybe chuck a can of upper engine cleaner through her? To add some information to this the engine has only 140k on it. I believe the valve stem seals are worn. Richard Baddock thinks it's also oil in intake but we don't know why. Will continue to monitor and start saving for new motor me thinks
