low temp thermostat\high pressure rad cap
nztintin
Is it worth getting a high pressure radiator cap and\or low temp thermostat? I'm getting a alloy radiator and upgrading radiator hoses so was thinking of doing this at the same time. Car is semi daily driver\weekend mission\casual track day forester.
 Optical said:
the zerosports lower temp stat was a good addition for me, i couldnt find any difference in the datalogs after fitting the 1.3bar cap though.
Depends, what is your cars main use Optical?
I run from factory a 0.9 bar cap, i wouldn't run a higher pressure cap.
Haven't tried it so can't say, but have done my research; just not willing to see what will happen.
 BC5RA']
making power :)
runs at approx 93degrees on the oem stat, 82 on the zs stat. I see no advantage in the former, but having a programmable ecu makes it easier to exploit though.
higher pressure cao just raises the boiling point for more headgasket insurance
Guest boostin
 Optical']
making power :)
With the flip side being higher risk of hoses bursting. Hmmmm, rock and a hard place there....
As he is upgrading his hoses and using an alloy radiator i don't see why he should worry about anything bursting... (assuming its all of decent quality and his end tanks aren't plastic)
Guest boostin
I was more saying that so Joe Average doesn't go out and slap one on his 20 year old RS thinking its a good plan and blows a hose and cooks the engine.
yeah good quality full alloy rad and silicon top and bottom hoses from sta parts, will get the other hoses too in time, will leave the rad cap till i get all the hoses done, might look into a low temp t\stat, can't hurt having a new one!
