2003 2.5 RS rattle on start up after a week of being parked up.
JamesRS
Hey guys
James here from Hamilton
So tonight I started up my 2003 2.5 RS IMPREZA for the first time in a week, initially it make a loud knocking noise while the starter was cranking the engine over, the battery absolutely battling, I quickly stopped cranking when I heard the loud knocking noise. tried to start it again and it turned over alot easier but made a rattling noise, which eventually ceased. basically wondering if my EJ25 SOHC has hydraulic lifters and if this caused the issue due to the oil draining out of them over the course of the week. I am currently using 10w40 and my engine has done 230000 ks
Welcome to CS James. The loud knocking noise while cranking could just be the starter motor solenoid struggling due to the flat battery.
You're right on the rattle that faded. After sitting for a while the oil drains out of parts like big end bearings etc, that can cause rattles on startup until the oil gets pumped around. More noticeable on higher km engines with worn clearances. If it carries on changing to a 5W30 oil might help.
