BG front shocks removal
Guest NZBG
Trying to get the front shocks out to put some proper, uncut, springs in and I can't get the barstard bottom two bolts undone?? Any tricks??
Thanks guys, snapped a socket adapter lol, and then bent a cross bar using a breaker bar. Got it with a spanner and a 3Lb hammer in the end :D Now how do I get the top of the shock off? (out of the car now) can't see a big nut?
Sorry I should've been clearer. Have the thing out of the car now, never mind the spring compressors, I've got a tower stand :D just can't seem to get to the big nut that's gonna let me get the spring out of the tower...theres a big rubber cap that seems to be part of the top plate?
 Drunkenmonkey said:
if the spring is lose due to being cut you wont need compressors to get the top hat off...
Too right mate, she's loosey goosie alright!
Youd still need one to get the new ones in.
That rubber cap just pops off. Then youll need a 17 or 19mm socket i think or a ring spanner and a grunty hex key to stop the shaft turning
 keltik']
Beauty, thanks!
I did mine using an old socket i didnt like. I filed 2 flat bits on it and used a vice grips to turn it. Then a big hex key can be inserted through the square hole in the socket into the strut to hold it still.
Harder to describe than it is to do.
 DRFVDR said:
luckily I have a well equipped workshop :)
Your not talking about a blue shipping container with a brumby in it are you?
Those electric rattle guns any good?
Used an 18" f-tool on the shaft(don't worry I did it where the bump stops cover) with tthe nut in my ground down socket sitting in the vice...sounds painful I know...
Did the trick. Second shock took 20mins total from out to back in.
Thanks for the help!
