Over boost then returning to normal
RaKid
Hi Team,
Boost gauge has recently started reflecting 19-20psi boost spike on initial wide open throttle (WOT) then returns to 15.9psi (1.1bar) after a few seconds. My understand is that 1.1bar is stock internal wastegate (IWG) pressure - could someone please confirm this?
Turbo is VF28 and vehicle is V5 STI.
From the symptoms I believe that my IWG diaphragm has a hole and is leaking boost which is why it's taking 19-20psi to open it - could someone please confirm or deny this? Please provide a fact based response if you choose to do so.
Secondly, for the duration that my wastegate is not efficiently releasing waste, 2-3 seconds, are my injectors pushing the required fuel into the cylinders?
TIA. Brett
Which car? The v6?
Your diagnosis is probably correct assuming nothing on the car has changed. To verify it's not simply the ecu doing something weird do a reset and see how it behaves
as for the fuelling - "probably" - can't be 110% sure. They generally are fine at the 18psi range but depending on modifications it could be pinging for that brief period
to answer if you think it's the gate itself - get a bike pump feeding into it with your boost gauge teed off
