Adapting V2 tps to V3 throttle body?
driftrex
yeah no problem - tomorrow
in theory you can reverse the wires, electrically its the same. i never tried it though.
there is an idle switch built into the v2 tps. WRX8YA used an attachment off the throttle and microswitch - probably about the same amount of work in the end.
I did it on the standard ECU my running a mechanical micro switch for the idle switch wire. I have a friend with a link and he simply dropped the idle switch wire. I dont think the link uses this? I had to reverse wire the TPS but it all runs fine now.
Here is a pic of the micro switch which joins the 4th wire to one of the others when the throttle body butterfly is closed.
