Spark plugs
redbeard45
Just attempting to replace the plugs in my import 2007 B Sport Wagon with 2.0 n/a motor (had since Easter and just clocked over 100,000 clicks.
I canʻt find what the gap should be for the plugs (PFR5B-11) anywhere. It had no hand book - even in Japanese.
When I pulled the plastic plug tubes out, they were covered with oil, as was the plug. Is this normal or are there o rings at the bottom of the tubes that are gone?
It doesnʻt look like you can do the passenger side of the engine without removing the battery. Apart from having to reset the stations on the radio, are there any other dramas associated with this, e.g. alarm, etc
Thanks very much for any help offered to a Legacy newbie! Really enjoying the car so far.
Found out the plug gap seems to be 1.0 - 1.1mm    Horrible job to replace. Got the driverʻs side done eventually after removing the air filter boxes and trunking and loosening up the bracket to what I think is the Anti Locking Braking to get the rear driverʻs done. Not sure how you do the rear passenger without special tools?
