Injector Plugs?
evlRA
Hey i have a 1995 wrx sti ra which had grey tops factory standard, now i have Sard 880's and the injector plugs appear to be different, but only slightly.
Does anyone know if injector plugs change in the later models?
Thanks
yes they did. can you modify the plugs to suit??? im pretty sure it was kind of square for early ones and oval for late model ones.
Don't cut them off. Just lift the plastic tags and pop the wire terminals out. Saves a poor connection later if the soldering isn't up to scratch.
i had this prob when i went to Apexi 550's. Just do what boostin said, you can get the new plug, and push the wire tags back through.
From memory the factory ones are.....(not sure) and my Apexis had a Bosch fitting. Most tuners can tell you off the bat what you need and mine here was easily able to source the plugs. (they werent $$)
