4-plug to 3-plug conversion, few questions
ReubenH
I'm just working on making ryan's adaptor to run his 3-plug 6S in the BF. I've come accross a slight hitch. Power power power...
I have 2 pinouts for each ECU type, so in total 4 pinouts for reference, and this is what they seem to say.
On the 4-plug loom:
B2 = ECU Power Supply
B13 = ECU Power Supply
B15 = Backup Power Supply
On the 3-Plug ECU:
B1 = "Main Relay 12v" or "Power switched by relay"
B2 = "Main Relay 12v" or "Power switched by relay"
B22 = ECU Power Supply 12v
A15 = Backup Power Supply 12v
So, when wiring up the adaptor:
Backup powers easy. B15 goes into A15. done
But power supply, i have 2 pin's saying supply on the 4-plug, there's no distinction between them; but on the 3-plug, there's only one pin that says "power supply". Then there's those 2 other relays...what do they do?
I could take one of the 2 supples in the 4-plug loom and connect it to the 3-plug ecu, but what about the spare one. i'll have one spare power supply wire, and an ECU wondering what happened to it's 2 12v relays...
I'm confused...
 pl0x said:
i may be lost here, but dont you 2 power supplys and need 3?
join b2 & b1 together?
Makes sense to me.
Is that what I had down Reuben??
