pressure in the top rdiator hose
 driftrex said:
yea what he said, unless your temp gauge is reading higher than normal.
um not quite right it should be at 14 psi no higher unless you have changed your radiator cap or it is faulty:)
a 14 psi cap will raise the boiling point of water to 114degrees C
rule of thumb is 1degree Celsius per Psi of cap pressure :)
 DRFVDR']
what i meant was unless his temp gauge is getting higher than normal i wouldnt worry bout it as its normal 14psi. if it was getting hotter the cap might of been stuffed or something and therefore could hold more pressure :)
