Boost solenoids with aftermarket ecu.
5UBZRO
Just in the process of wiring up an eboost to my rex and was wondering while im at it, what are the 4 solenoids/things with wires out the ass of them on the right hand strut tower? Because the car will be running an aftermarket ecu ie link g4 with the e-boost, which of these units can be removed? i will try add a pic..... oh and the car is a 97 wrx sti ra
Guest itsgotgo
you will only have to plug the boost control solenoid with the eboost controller. :)
Unsure if all the rest can be removed before the aftermarket ecu has been installed :-\
Guest itsgotgo
 nt_a_foz said:
Once the link has been installed you can remove all the other crap..
My solenoid as teh same as on your foz will i spied it the other day when you were round
your solenoid is the link one aye brad?
you talking about the turbosmart one in mine,or the standard one?
I have just about had it with the foz >:(
Cannot figure out the idle issue and now has a bloody boost leak.......pisssssst to say the least >:(
