Best Oil
I use to use valvoline 10w40 but then had a friend that can wholesale me shell oil for half the price.
I found that the valvoline seemed to disappear after awhile and I had to keep topping it up.
Shell stuff is better tho, Doesn't need to be topped up much.
Also any idea why mine goes black so quickly ?
i posted this in another form.. i guess there should be a sticky or what ever about this really na na really.. anyway this is my 2 cents i said to some one
http://www.clubsub.org.nz/forum/index.php/topic,6135.0.html
ok im so going to do what you should of..
OIL is the most important thing you pour into your car! $80 oil transfers heat better than $40 oil unless you got $80 oil on special for $40,
also $80 oil holds silicon oxide better, oxidation at higher temperatures, bla bla, look it comes down to Phosphorus and how much is in the oil because phosphorus is the shiz in oil and it cost $$$$$$$$$ so $80 has more and $40 has less simple, know what you’re putting in read the labels on the back
