Intermittent horn problem
rico
Hi, every now and then (more frequently lately) my horn will just go off by itself when Im driving around. If I push the steering wheel button a few times I can get it to stop eventually, but does take a while sometimes, and needless to say can be pretty embarrassing!
Also I can here something is loose behind the steering wheel when I turn the wheel a lot (like while parking). Sounds like coins or something rattling around, so Im guessing a bolt or something has come loose and is maybe whats causing the horn to go off?
So I want to take it apart to see whats going on but its the factory momo wheel with the airbag and don't want to cause any problems there, can I just disconnect the battery before taking it apart?
Cheers for any help.
Its a 1997 legacy gtb. Figured it prob wouldn't be as easy as just disconnecting the battery. I know something is loose in there and figure thats probably whats causing the problem just sux I have to pay to get someone to undo a couple bolts and check it out.
Sweet, thats good to hear. Im hoping I wont need to unplug the yellow airbag connector behind the wheel but if i do then plug it back in will this cause problems with the airbag light? Don't really see how it could but think I read somewhere that it does and then needs to be professionally reset?
when i removed my air bags all i needed to do was disconect the battery, then give it some time, just needs to let the capacitors discharge really, i left mine over night, just coz i started it then couldnt be assed hahaha
-smurff
 DRFVDR said:
I have done this numerous time and disconnecting that battery works fine,
I still have an airbag wheel in me shed that I am dying to set off :)
+1 to that, got the pair from my leggy, so want to set them off would be sooooooo much fun!
-smurff
Guest itsgotgo
 boostin said:
Set it off in an old microwave, fridge/freezer or something.
My xr6 in aussie set the the airbag off driving home on the M1 :-[
2 black eyes and a blood nose,didnt know what hit me and i was doing the 110kmh speed limit :o
Faulty sensor in the front bumber set it off.
