This is probably a stupid question but what does a green 'POWER' light on the dash indicate?
Signifies the auto trans is in one of 3 modes - hold / normal / power
'Power' changes the shift points supposedly to a more 'sport' mode up the rev range
I find with mine it will tend to hold a gear longer, and will kick down quicker.
If you tap the throttle down quickly it makes the trans go into a more sporty mode where it changes up at higher revs and kicks down sooner. Tje changes are also crisper. If you back the throttle right off for more than three seconds it reverts back to the standard ecomomical mode.
