ECU help
Guest dcornie
Guest dcornie
hey all i have just bouhght a v6 sti ecu do i need to change any of the pins over if so which ones
also since i have the ej205 engine do i need to replace the air flow meter???
Plug it in and see what happens I say. You might need to get the AFM. Your car came with yellows etc didnt it?
Guest itsgotgo
yeah dave,you would have to go the same as mine,v3/4 and orange afm.
Am surprised you didnt check the plug layout before buying the one you have ;)
Guest dcornie
my engine is the phase two
it has the new 3 plug ecu not the same as the v3/4 ecu
therefore i have to re pin the whole lot
thank f*** i have found jdm sperc wiring diagrams
