help with bushings. FIXED
ok so just failed my wof, one thing written on the sheet
L/F bottem arm rear bush
apparently its leaking silicon.
are they cheap enough to fix? i.e how much
and where can i get some in chch.
Over $160 per side from Subaru. For $180 you can get a nolathane kit for both sides and replace it yourself in 30 mins. Warning though, the nolathane ones can creak.
Guest itsgotgo
Used to use nolathane bushes in the trucks we built in aussie.
Best thing to do is spray the bushes with a good silicone rubber care product,so that it soaks it up and impregnates into the rubber.
Always use some white sealer grease around the out side before inserting the bush also :)
 wildturkey said:
yes go nolathane or whiteline that will tighten things up nicely. Just make sure u grease pack them well like the others said. you may 'feel the road' a little more with aftermarket bushes
You will definately feel the road alot more, if you want to wait a couple weeks I'll have a set of 10k old nolathane ones you can have for bugga all, I'm changing them for a whiteline antilift kit but I have to wait for it to arrive, Im guessing BG and BH use the same ones?
