My hazard lights are not working
Guest lan_killa
i would say your switch is buggered. if its unpluged/flasher broken/broken wire/blown fuse your indicators wouldnt work either, as your hazard switch intercepts the indicators
Not on a BL/BP it doesn't. All switched by the body control ECU, aka Integrated Unit.
Has someone had the stereo out of it? If so, then they will have forgotten to plug the hazard switch back in. I've seen it so many times its not funny.
Yeah its a BL5, the trip meter unit was replaced earlier...anyone know how to remove the centre console to access the plug??
I figured it out on my ol BE5 but this is a whole diff. kettle of fish with the integrated steeo/aircon unit...
Cheers...
Pop out the chrome ring around the gear shifter. There's a clip in each corner.
Lift the front edge of the cup holder section about 2cm. The clips for this are f'n tight.
Take the shifter surround out. Pop the back edge up first.
Take the screws out of the rear of the side trims.
Carefully pop the side trims backwards. 3 clips on each one.
Remove 3 screws on each side of the stereo-A/C panel.
Move the shifter to "D" and pull the stereo etc out.
Refit all in reverse order.
  • 2 years later...
I know i've dug up an old thread here, found it when searching.
Our hazard lights don't work in our 2003 BP Legacy...the indicators do work.
I've followed this thread and have removed the facia...friggin paranoid i'd break something, bit reluctant to pull the radio
set up out any further cos it's pretty tight.
Anyhow, the hazard switch is unplugged...there's no wiring to it. Where the hell would it be???
lol thats a 1st someone complimenting the search function :P
wicked result I know because if I didnt say it already in my BG if I unplug the hazards the indicators DONT work
(had to trip to ripco for a connector mid-gauge install)
