diff ratio matching
hi there,
I'm doing a manual conversion on my Hx20s impreza soon and have got a gearbox etc already, just wondering how I would find out if my rear diff ratio is the same as the front diff i got with the gearbox?
hope someone can help, cheers
 readosnr said:
and what is the ratio of your rear diff?
or if you want to use your current diff then you need to tell us what the current gearbox number in the vehicle is
manual HX20s are a 3.9 ratio, manual turbos are either 4.111 or 4.444. I am not 100% sure of the stock ratio of your auto HX20s, but the R100 rear diff will not like having the extra 'roughness' of the manual gearbox very much and should really be replaced...
 K City']
[quote name='boostcut said:
WHAT IS THE CODE ON YOUR GEARBOX?
numbers i've got a re 903689 and 9B-TY752VSBAA thats the manual gearbox. do I need numbers off auto as well?
That sounds like a cable-clutch transmission? the HX20s is meant to have a hydraulic clutch system. TY752VSCAA
Edit: wrong trans code.
