o2 sensor???
kingersman
ok now after this car broke down( possibly the turbo still checking for other problems) we took the turbo off and noticed that a place for the o2 sensor was welded shut and then later found the o2 sensor plug sitting there. havnt found if there is a 2nd o2 sensor futher down but any ways..... would no o2 sensors cause the car to run rich as **** and be a little grogy cold?
ECU won't use the o2 untill motor warms up to temp, with it out it will effect the mix but not too sure if it would cause it to run horrably rich like you state.
it would back fire like a ***** and well you could smell unused petrol in the cabin. previous owners has said its always run rich but dont know why... just wont to try and find out more. ecu been stuffed with as well so might be that as well :S(nothing but carpet holding it down and 1 screw around the electrical)
 boostin said:
The injectors splash fuel out?? Like over the engine??
When mine went there was fuel coming out the slip joins on the headers, and the front and back of the turbo. Wasnt good! fuel everywhere
