1990 gt legacy gear ratio???
hey guys im new to this site and i have a question i hope u might be able to help me with. i have a 1990 gt legacy
just put a 1994 wrx ra gear box in the old girl apparantly it has a 4.111 front diff to match my rear.
The problem is at 100 its at 3500rpm wich seems real high and it uses a shit load of gas any ideas??? or is this normal? any help would be apperciated cheers clive.
The problem is at 100 its at 3500rpm wich seems real high and it uses a **** load of gas any ideas??? or is this normal? any help would be apperciated cheers clive.
It's perfectly normal.
Only option is to remove it and put something non RA in there.
Forget about rear diff ratio's; in this case it is the transmission ratios that are the reason for high RPM in 5th.
sweet as i have only just bolted it in so will make do for a bit also 2nd to 3rd is close as lol just got to get used to it. are they a good strong gear box thougth?
