How much movement should the gear stick have on an sti box?
ben-jamminn
You people out there with a non ra (short shift) sti gear box (version 3 in particular)
how far does the gear stick wobble when you are in gear? cos mine seems to do it quite a bit,(about 50mm centre to cente) it feels the same as my old toyota hilux! but i've got nothing to compare it too, as the only other subarus i've driven have been RA's, with the nice tight box.
I searched, and found something about worn bushings?
So if it sounds to you guys like mine has excess play, I guess I have that problem
Cheers!
theres a spring underneath the car on the bottom of the shifter, which sometimes comes off that helps the shifter return to centre and stop it wobbling around. that might of come off.
