Help please with wiring towbar wiring kit into tail/brake lights
sooby
Hi Guys ~ Im halfway thru wiring up my new tow bar wiring kit and have had no trouble doing left and right indicators, earth, etc.....but have one wire left to connect and one last question:
I went to hook into the brake lights & found there are three possible wires to connect to, here is a photo: 115658789_full.jpg
The wires are coloured from left to right: solid black, white with black stripe and solid red. The black wire seems to terminate on the side of the unit, whereas the other two fit thru the bottom.
Which one do I connect to?
car is 1996 JDM wrx sedan
Cheers!
 gazzy2000']
[quote name='sooby said:
cheers mate - I guess i should just link into the red one, knowing that if its wrong its definitely the other one then! lol
really a test light is a HUGE help, its just painful & time consuming playing the guesssing game
ACtually man i just found a diagram and the White with a black strip is the brake
 sooby said:
Thanks gazzy2000, appreciate that heaps!
I actually had have that diagram too - but could tell which was which, how did you know?
You can see the letters WB (white with black) on the actual stop light wire, the other is B for black (normally earth), couple that with the pic you sent it makes sense.
