What is this sensor?
KarlGTB
Thats oil, not sure if its from a recent spillage or leaky rocker cover.
Theres this sensor right down the bottom of the down pipe or...
looks like wires going into the downpipe about half way down but cant really see it with the intercooler still on
I think it probably should really go on a select monitor rather than me attempting trail and error, but i've wasted my money twice with muppets that come back to me with "well theres no codes". Anyone can check the codes, but who in wellington can actually check that the sensors are performing properly for a resonable cost?
Guest boostin
The first one is your oxygen sensor.
The second one is the cat temp sensor. The light on the dash tells you when the cat is overheating.
Guest boostin
If the cat blocks up you'll have low exhaust flow, and low heat. The engine will choke when you try to rev it.
As for the light and wiring, it all depends on how the circuit is wired as to what you earth and what you leave open circuit.
