Power output
Earl
 JoKer said:
AAAaaactually on the Legacy range the Wagon has sightly better/Lower wind resistance
I cannot recall source or figure but is true AFAIK for the BD/BG range
Pretty close... That's one reason why they used the Wagons in the Utah Salt Flat Speed Trials.
 kamineko said:
JDM:
97 WRX SEDAN is EJ20K engine with VF22, yellow 440cc injectors, larger AFM etc pretty much STI minus the internals.
97 WRX WAGON is older EJ20G engine (block only) with TD04 and grey 380cc injectors, smaller AFM diameter.
Does anyone know the changes between The different EJ20's??
Or where one can go to find out??
IE Whats different from EJ20G to EJ20K etc etc
